Thread: Got tuned today, some goods and bads
Created on: 05/21/09 08:41 PM
Slowninja
05/21/09 8:41 PM
First of all, the tuner was pretty awesome. He let me stand dyno-side the whole time, let me work on the bike, let me give my inputs on adjustments and stuff.. really cool.
I got everything on, PC3, nitrous, ignition module, airshifter (although that doesn't matter on the dyno).
The bads...
Ignition module didn't work. I don't know if its the wrong one or if its broke, but it wouldn't accept any adjustments over 6k rpm.
His printer was broke.. So i didn't get any printouts.
The brand new nitrous solenoid stuck. Which means i got no nitrous tune-age or pulls.
He claims his dyno reads LOW, meaning i'd get higher numbers anywhere else.
It was an hour and a half each way. lol
The final results:
194 rwhp, 110 ft/lbs of torque.
It ran a 9.02 on pump gas and the baffle in the exhaust. I put race gas in it, and pulled the baffle before the first dyno pull so it naturally already gained power before he even tuned it. Before he tuned anything, it made 184 and 101, meaning i gained 10 HP and 9 ft/lbs.
Needless to say, regardless of the downers in the day i'm still pretty excited.
Resident Drag Racing Expert.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
muzz14
RE: Got tuned today, some goods and bads
05/21/09 10:08 PM
Hey, where did you get tuned? Im here in the city and was thinking about having mine tuned on my vacation this year. Thanks
Slowninja
05/21/09 10:09 PM
Metric cycles, its in tulsa. Guys name is brady, very cool guy
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
wfobusa
05/22/09 2:57 AM
Your brand new nitrous solenoid may have stuck due to pieces of teflon tape inside the system if you used it on any of the fittings.. I had the same problem..just dissasemble, blow out and go light on the teflon..I also had better results filling my air-shifter bottle with nitrous rather than compressed air. the extra cost was minimal due to the tiny amount needed to perform the shift..
Nice dyno numbers btw .. !!
Slowninja
05/22/09 10:05 AM
nope no teflon. this is my first bike nitrous experience, but i had been doing nitrous on cars for about 4 years prior
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
Badzx14r
Badzx14r's Gravatar
05/25/09 6:47 PM
had a dyno pull this weekend just to check bike out 283hp @ 9 lbs i got all the pulls on flash drive ...
and i sux at the track last weekend couldn't get hook-up @ 14lbs.. a 3 year old and a big wheel would have beaten me..
05/27/09 6:49 AM
"... and i sux at the track last weekend couldn't get hook-up @ 14lbs.."
Get'em, Slow! Hey, Rotty, bring your off day that day. U2 still on or WOT?
BadinBlack
BadinBlack's Gravatar
06/03/09 7:52 PM
Rob are you running 14lbs with no intercooler or water injection? Just pulling timing on the stock motor? If so we got ourselves one tough motor in these bikes
lemosley01
06/06/09 7:58 PM
SAE or STD and what mods?
Mind telling us what map you were running prior to the tune? That's a nice gain - how much did tuning run you?
Badzx14r
Badzx14r's Gravatar
06/07/09 6:55 PM
bone stock motor ..only add-on is a lock-up clutch .. AVGAS... -2 degrees ...20 passes .. i'm testing
can't stay hook-up or if i do hook i'm looking at clouds at 63 inches
* Last updated by: Badzx14r on 6/7/2009 @ 6:57 PM *
BadinBlack
06/10/09 6:28 PM
Wow Rob.......these motors truly are bricks when it comes to boost. I won't feel so bad running 8lbs with stock timing now......thanks for the info
